- Sep 5, 2005
The idea of a sandwiched, multi-layered steel makes sense if the middle steel is Carbon V and the two outer layers are 420 stainless, but I fear that CS is pushing its luck by trying to sell a San Mai steel that's VG-1 stainless in the middle and 420 on the panels.
What POSSIBLE advantage could there be to layering two stainless steels? You've got VG-1 in the middle acting as the super edge retention steel, then you've got the 420 as panels supposedly adding "toughness"? Is Cold Steel really trying to sell the idea that the 420 on the sides is really going to protect the VG-1 steel from blows?
VG-1 does have higher edge retention than 420 and I suppose 420 is more corrosion resistent than VG-1, but are the two dissimilar enough to be layering them?
I'm still not clear on whether VG-1 is a major upgrade from AUS 8A or not. Corrosion isn't an issue with me, but edge retention and toughness are. So far, I haven't been able to find out if VG-1 is SUBSTANTIALLY better.
I have Vaqueros in both AUS 8A and VG-1 and performance wise, I can't see much of a difference. Of course with serrated blades, I don't think there would be. The latter may be more susceptible to losing teeth than the former, but neither has been a problem with me.
