VG-10 vs. ZDP-189
From what I read here there are quite a few people around who've got both a gray Calypso Jr. in VG-10 and one of the burgundy Calypsos in ZDP-189. As both knives have the same blade shape and a fairly similar edge geometry, they allow pretty good comparisons of the properties of the two steels, and I'm quite sure quite a few people have done such comparisons already.
Among the differences I noticed so far are that ZPD-189 is even easier to sharpen than VG-10. That's kind of amazing, considering that VG-10 is already very good in that respect, much better in my experience than, for instance, S30V. But I also noted some microchipping that I never had with VG-10. That's after using my burgundy Calypso Jr. for a couple of weeks for typical household stuff, that is no really hard cutting. Alright, it wasn't *that* much microchipping and easily sharpened out, but the damage to the edge was easy to see at 6x magnification. My gray Calypso never showed that kind of damage after much harder cutting.
Hans
When you say ZDP is easier to sharpen, do you mean it takes less time or it takes sharper edge or both? Do you you use sharpermaker to sharpem them?
I found them both comparable for sharpening ease. I noticed a bit of microchipping also after the first sharpening and that was all. None after that. This is quite common with superior steels. I've seen this same thing with Japanese White and Blue steels in my wood carving knives. It is a sure sign of a great steel to most of the Japanese makers so it didn't bother me to have to put a microbevel on it and continue on. It has done nothing short of astound me with its edge holding since then. ZDP189 can go for about double the length of time in hardwoods as VG10 before needing the edge touched up, and perhaps a bit more than that even if I push it. The only blades I have that can keep up with it in carving hardwoods are the ones of Japanese White steel at Rc65.
Both on the first question. It's easier to sharpen, and it takes a sharper edge. I find ZDP-189 is really close to a good carbon steel in that respect.
I don't use the Sharpmaker, I sharpen freehand on diamond and ceramic hones most of the time. I also sometimes strop my knives on a loaded leather strop.
Hans
It's weird. I didn't have that problem the first sharpening, which was a very minor touchup, but I started to have it down the road (the opposite of how burring problems usually work). It could have been worse, but you know it's happening when there is no edge burr but for some reason the edge just won't take that very last bite. But it would still get very sharp quickly, just not wuite as sharp as the factory edge.
With even more sharpening and a lighter touch on the stone, I improved the edge even closer to the out-of-box condition. Then I cleaned the stones on my sharpmaker, giving them the best cleaning I had bother with so far. That did it. With nice bright white clean stones, I got that super sharp edge.
That too was weird because the unclean stones that wouldn't restore the ZDP189 seemed to still be doing OK on VG10.
It's a little disappointing to have that happen, but even with the very small micro chipping ZDP189 seems to hold a very sharp edge for a long time. For anyone who doesn't have a ZDP189 calypso, we are talking about "chips" you don't see with the naked eye.
s30v's edge burring under sharpening and use is also disappointing, though again only relative to what a steel could be. It's still very good stuff.
If you are having trouble with the s30v, do two things:
First, give it a long thorough sharpening with diamond stones at a low angle (30 degrees total on a sharpmaker). If the edge is "bad" from fatigue or who knows what (including a careless sharpening job resulting in a forced burr), it adds to the burring problem and makes sharpening difficult. s30v is extremely resistant to wear, so it takes more sharpening to get rid of that compared to other steels.
Second, once you are rid of the bad steel on the edge and sharpened it carefully to avoid damaging the edge, add a micro bevel, maybe a little more of a micro bevel (removing more steel total) than you would with other knives, at a higher angle (40 on sharpmaker). Be VERY careful when adding the smaller bevel, as you don't want to bend the edge and ruin your previous efforts. Depending on how much edge burring you are inclined to notice or care about, you way even want to change that to a steeper angle. I tilted my Native blade a little bit to increase that, and results are more satisfying.
With careful sharpening, you will notice s30v's advantage of being very fine stuff. Even when bent, the steel remains very smooth, but with an adequate micro bevel you can really reduce that. It also wears down very slow, so if you use a steeper final edge angle you can really make use of its benefits while reducing its disadvantages compared to harder steels.
Cliff complained about the Sebenza (s30v) having a thin edge with a steep final bevel. After working out the "optimum" (yikes!) edge profile for my s30v native, that popped back into my head and I was thinking maybe Chris Reeve has the right idea. Of course, a micro bevel arrangement would be better and I would have to see the Sebenza in person to know how it is working out.
A side note, going back to s30v taking longer to get rid of fatigued steel on the edge, that's pretty much why Carbon and tool steel fans don't care much for stainless. What a good Carbon steel can do with high hardness (that "what" being remaining in good cutting form), a lot of the popular stainless steels try to do with higher resistance to wear. You could conceive of a stainless steel and a Carbon steel which acheive roughly similar performance like this (just imagine the edge burr on the stainless equaling the width of the worn area on the Carbon steel). But burred steel is weakened and tends to flip flop when sharpened. So then to get rid of enough steel to restore both to equal sharpness, which steel is going to most resist wear from the sharpening stone? Depending on the exact steel and hardness in question, you will either take a lot longer to sharpen the stainless (like s30v), or else sharpen it as fast and have constant new edge burrs forming. That clears up the mystery people run into who are familiar with stainless and hear that Carbon steel is easier to sharpen and lasts as long, or even lasts longer (depending on the steel in question and how the advantages are spread). So it's no surprise that a lot of people who are acustomed to stainless are big fans of the enduring and smooth s30v and notice mainly its improvements, while fans of tool and Carbon steels (like me), waiting for popular stainless steels and millions of dollars of fancy technology to catch up with non-stainless steels, try s30v and think "well, it's better than ats34 but it's still another disagreeable stainless steel that doesn't play well with stones and I would rather have my M2/D2/52100 at higher hardness."
Carl64 said:
<on ZDP-189> It's weird. I didn't have that problem the first sharpening, which was a very minor touchup, but I started to have it down the road (the opposite of how burring problems usually work). It could have been worse, but you know it's happening when there is no edge burr but for some reason the edge just won't take that very last bite. <snip>
If you are having trouble with the s30v, do two things: <snip of lots of good advice on sharpening S30V>
The chips I had on my Calypso Jr. were pretty strange. There were only 4 of them, all clearly visible at 6x magnification. They looked like tiny pieces of the edge had actually broken off, and it took some time to sharpen them out on a diamond hone.
I'm not sure, but maybe the steel isn't really tough enough for the pretty acute angle they put on it. I've never seen such chipping in carbon steels, at least not after light use. And like I said, I didn't really use that knife hard at all.
BTW, I've still not succeeded in getting my Calypso Jr. as sharp as it was when I got it, but it's quite close. Stropping doesn't seem to work all that well with that steel, at least I didn't find any clear improvement.
On the subject of sharpening S30V: I just tried the method you describe with one of my Natives, and it works very well with S30V. Maybe I should really use the sharpmaker a bit more ...:) I usually sharpen with the knife in my left hand and the hone in my right, and using this method I tend to get a sort of "semi-convexed" edge because I can't hold the angle very well. The edge I get isn't as pretty as the one I get on the sharpmaker, but the knives are sharp and there's a lot of metal behind the edge. Once I had learned to get rid of the burr my old Native in CPM 440V (now S60V) held a pretty good edge for a long time.
Hans
I didn't realize you meant such large chunks in individual spots (rather than a blade wearing down to a rough edge from tiny fractures). I have heard complaints of larger chipping on various individual knives of different models. I have not seen it myself, but I usually don't put a knife to anything worse than cardboard (although a solid cardboard piece can be harsh with curved cuts). In the last few months someone had a problem with small chips in a "byrd" (made in China from 440-like steel) and in another case some s30v blade (large s30v discussions, I forget the model). In both cases the people with the problem sharpened the knife down to get rid of the missing chunks and said they never had that happen again.
I still have mine sharpened at 30 degrees total. You might want to just sharpen it again down to that angle and see if the problem doesn't go away on its own. I am not too rough on my knives either, but I do tend to be more gentle when I first get them until at least the first sharpening. Maybe that's why I never run into the chipping problem, assuming it really is usually limited to the very edge when new.
I cleaned my stones with soap and then acetone. They have also been used for a few months, so the end result was a very smooth stone that was completely clean. The last bit of sharpness it had from the factory isn't easy to get, but then we are looking at sharpness beyond what we normally expect. I was thinking about getting the ultra fine stones they sell, but I don't have many knives that are worth sharpening that extra level.
I rarely use regular stones any more, The sharpmaker is just too convenient. I should probably do it the old way now and then so my skills don't dwindle. :)
Hey, some people complain that it's hard to get the convex bevel on purpose. Consider it a skill. :)
Carl64 said:
I have heard complaints of larger chipping on various individual knives of different models. <snip> In the last few months someone had a problem with small chips in a "byrd" (made in China from 440-like steel) and in another case some s30v blade (large s30v discussions, I forget the model). In both cases the people with the problem sharpened the knife down to get rid of the missing chunks and said they never had that happen again.
Actually, I had such problems before, with my first Native in CPM440V. I also had some visible chipping after using it with the factory edge for a few weeks. I sharpened them out and had no more problems after that. No problems so far with S30V, and I've used my UK Penknife quite hard over the past 6 months or so.
Well, I usually EDC my new knives for a couple of weeks once I get them, and they've got to do a job then. I prefer it that way, gives me a chance to sort out out much I like the knife. BTW, my Calypso probably won't make against my UK Penknife, mainly because the UK Penknife has got a much better handle. The Calypso is a better slicer, especially the burgundy Calypso with its very acute edge, but the handle makes all the difference. YMMV, as usual.
Agreed, but that's where the real fun starts. I started using carbon steel knives again some time ago, and while I haven't got a carbon steel folder that meets all my requirements I prefer carbon steel over stainless when it comes to pure cutting power, provided of course the knife has a suitable edge geometry. And with carbon steels I find it pretty easy to get the sharpness I like. They seem to take stropping better than most stainless steels IMO. I'll be getting a custom in M2 hardened to ~63-64RC in a few days, and I'm already looking forward to trying that one out.
BTW, I also think clean stones make a difference. I try to make sure my hones and ceramic stones are always *very* clean. Some washing-up liquid and some scrubbing usually seem to do the trick.
Hans
