MSCantrell
- Mar 12, 2005
Well I re-scaled my Christmas One Hand Trekker in some wood that was also a gift.
I'm pretty sure the giver said it was ebony, but it's a little more brown than ebony I've seen in the past.
At the same time, it's blacker than any walnut I've seen, either.
The grain is tight and swirls some- I like it a lot.
I haven't even oiled it yet, but it seems to resist water very well.
Anybody know a better test to tell which it is? I saved a cutoff...
The round metal bit is going to hold a clip. I just bought a little nut, turned it down to a circle, and cut off a machine screw to the right depth. Only problem is, the clip spins (I knew that would happen
). So the next thing I'll probably do is use a little elmer's glue on the screw. Not so permanent that you can't get the clip off, but enough to hold it steady so it clips right.
Mike
Mike
