VIC - SAK Fingernail File Blade???
afishhunter
Basic Member
Concerning the VIC (formerly Wenger) Evo Grip 18.
Can the VIC/WENGER Fingernail file blade be sharpened like a Pen Blade, or does it have the wrong (or no) heat treat?
(I'm guessing swapping in the pen blade will require several other changes - backsprings, blade order top and bottom ... basically the entire knife would need rebuilt and modified.)
If the fingernail file blade can be sharpend:
Is a 10 DPS "V" edge, or 10° single bevel chisel edge "best"?
Can the single purpose and redundent phillips blade be swapped for the multi-purpose corkscrew blade without changing the backspring or any other parts?
I like the work done by fit to survive on YT and the SAK mods thread here might be also a good place to ask.
Every sheet metal (heat treated or not) can be sharpened.
As far as I know they use different steel for tools as they use for blades.
Try and report the result.
I have no facts to offer but the other than blade tools might be slightly softer than the knife for some strength - but then again we are talking about file here so it might be harder.
Comparably to victorinox's soft steel it might not make much of a difference.
I did sharpen the tip of the finger nail cleaner in MiniChamp to micro screwdriver and it feels sharp but I can't tell about the edge rentention. :D
I found an old thread that gives information published by Victorinox. I don't know if that's still valid as it is ~ 20 years old.
Blades 56 HRC.
Saw, scissors, nailfile 53 HRC.
Openers, reamer, screwdrivers 52 HRC.
Corkscrew, springs 49 HRC.
Hope that helps.
Blades 56 HRC.
Corkscrew, feathers 49 HRC.
Hope that helps.
That makes sense to me. I know Camillus & other makers of the 'demo' style camper patterns made for the military spec'd those in a similar manner, with only the blades heat-treated for edge-holding, and other tools like the screwdrivers, etc. less hard and treated for toughness (resistance to breakage) instead of edge-holding & temper.
I have one Victorinox SAK with a slightly twisted tip on the screwdriver. In doing that, trying to loosen a (apparently) too tight screw with it, I wondered about the heat treat for it.
