JF-- I was just teasing with you before. If you want to sharpen your own knife, OwenM already gave you, IMHO, the best advice. If you want to have someone else sharpen it for you, you might want to look for a local cutlery store or sharpening service in the phone book. Personally, I would suggest getting the sharpmaker and a really cheap knife on which to practice. If you use your knife, any knife, it will eventually get dull, which means you will be taking it in to get sharpened for the rest of your life. The sharpmaker is easy to use, and with just a little practice, you can sharpen all your knives (as well as pretty much anything else you might ever want to sharpen) to a razor edge. The sharpmaker costs about $50, which seems like a lot of $, but once you start using it, you will see that it is worth every penny and then some. You might also want to read the sharpening FAQ here on bladforums, or do a search for "sharpening"-- this will produce more info than you wanted to know. Good luck,
--Josh
