(This is a different version of the Cadet, but all other measurements are the same. Some of this review is simply copy-and-paste.)
Today's review is for Victorinox' silver Cadet II, model number 55042. It's essentially the same as the Cadet, except the nail cleaner / file is replaced by a small blade. It's one of the slimmest SAKs available, and has Alox (aluminum oxide) handles. This is a discontinued model, but I remember seeing them for about $18 in stores. Here's the rest...
Handle Details: The Cadet II is 3.25" closed, and only .32" thick. This is a two-layer knife. The handles and liners are both Alox. Before I thought the liners were stainless in all SAKs, but I found out from SOSAK that they're actually all Alox. The handles are a checkerboard design. The left side sports the red Victorinox shield, while the right side has a small (.187" X .812") engraving plate stamped in. Three rivets (all brass) are exposed on each side. The Cadet has a keyring attached for lanyard or leash carry. There is no toothpick, and there is no tweezer. Sorry. I will say that the Alox used here is very strong and it really doesn't flex unless you white-knuckle it very hard. Using the tools is an ease, and while the handle isn't as long as I'm used to, it works very well here. The entire knife weighs only 1.6 ounce.
The Tools
Blade: The Cadet II's large blade is 2.5" with a 2.25" cutting edge. The nail nick is on the left side, as are the words VICTORINOX over SWITZERLAND over STAINLESS over ROSTFREI on the tang. The right side tang has the crossbow logo with OFFICIER under it, and SUISSE under that. The blade came out of the box very sharp, and was quickly made razor-like. It cut everything, and I mean everything, that every other EDC I've ever had has cut. Without trouble. Without needing to be resharpened. It only dulled when I whittled wood, and even that was after everything else was done being cut. The steel strops very nicely, by the way.
Small blade: There's also a small pen blade. It's 1.62" long and has a cutting edge of 1.3". It came razor sharp, as I intend on keeping it.
Bottle Opener: This is a standard tool found on most SAKs. It's 1.23" long and has the familiar tools... large flathead screwdriver, wire bender / stripper, and bottle opener. Since so much has been written on the uses of the bottle opener, I'll leave it alone here. It comes out of the same side of the knife as the nail file.
Can Opener: The other standard tool. It's 1.23" long and comes out on the same side as the blade. What can it do? It has a small screwdriver that's ideal for smaller flathead screws, and works very well on Phillips-head screws. It also opens cans with ease, since that's what it's made for. Stick it on a ferro rod and use it as a striker; it works very well for that too. I once heard of a guy who opened the can opener in a struggle and used it to slash the attacker's arm open, very badly injuring him. I don't advocate this, but it shows that this thing is really sharp.
So, how does this knife sound? Under twenty bucks, nice assortment of tools, reputable manufacturer, solid handle. Go pick one up.
The Tools
