It is not a bad little knife. I would have liked it to be a little more pointy at the front and the forward serrations on the point work fine. I cut rope, string, bread, meat and a few other bits and pieces with it and I find it much more useful to deep aggressive cuts on the back half of the blade that limit you to using half the blade at once. The rear part being plain is also more useful for carving, making feather sticks, and stripping bark.
The one handed opening hole is kind of slipperly. Can lead to some nasty cuts if you are not careful, so I tend to open it with both hands, and I little jimping on the blade ramp would have been nice. There also a little bit of play in the main blade due to how it locks.
The flat head screw drivers work really well. I like the locking bit one for instance. The can opener kicks butt. I can open a can pretty fast with it. The bottle opener has been used many times to open bottles of beer. I would have liked a sewing hole in the awl. It nice for drilling though. The tweezers and toothpick are functional. The Phillips head screwdriver is kind of short and awkward to use too. If you can get it to fit, you can put lots of pressure on a screw to loosen the screw, but many times it just not in the right shape for me to use when I am dealing with electrical and electronic stuff in the lab.
The handle is fairly non slip. I like it. Good ergonomics to it, not too large. I throw on a detachable lanyard loop my wife made and have a sheath that I occasionally use. Mostly it a pack knife since I have better tools to use for EDC, though it does the job fine. It does have the advantage of being very resistant to corrosion so requires little maintenance. That's always nice. It also easy to sharpen up. It is well worth a look at. I need to pick up a plain edge OHT yet.
