- Mar 12, 2013
Hey guys!
I originally posted this in the maker forum, but I think it's something that a lot of knife users/collectors will enjoy seeing as well!
I've been wanting to do a round of head-to-head testing on a bunch of different blade coatings for a while, and earlier this year I was finally able to do it! It took ages to finish the video because I've been so busy, but it's finally done!
Overall I tested 6 coatings/blade-finishes:
1) DLC - Diamond Like Carbon, a thin film of vacuum deposited amorphous diamond.
2) Cerakote - A 2 part epoxy coating that's sprayed onto the blades. Originally invented for use on firearms.
3) CrN - Chromium Nitride, a thin layer of nitrided chrome vacuum deposited onto the blades.
4) WCC - Tungsten Carbide Carbon, a coating that's a competitor of DLC, often used on injection molds in Europe, but not seen as much in North America.
5) WCC + CrN - A dual layer coating with CrN as the underlayer and WCC as the top layer.
6) Satin A2 - A hand-rubbed 600 grit satin finish on A2 tool steel (mainly for comparison).
You guys are all likely familiar with Cerakote, DLC and Satin finishes, but I found a few extras that I wanted to try as alternatives, and I still have a few that I'd like to try in the future, including low-phosphorous electroless nickel plating (possibly as an undercoat for the DLC which would be fun!)
To compare the coatings I did a variety of tests:
1) Cutting 400 linear feet of double-wall corrugated cardboard with each blade
2) Wood-carving with each blade
3) Splitting dry hardwood with each blade (poplar and mahogany)
4) Each blade stripped of any oil and wrapped in wet towels for 48 hours
5) Each blade lightly oiled (with mineral oil) wrapped in wet towels 144 hours
All of the blades were made from A2 tool steel, heat-treated to 62.5HRC.
Without further ado, here's the video showing the full testing!
[video=youtube;s6cKjbDToXU]https://www.youtube.com/watch?v=s6cKjbDToXU[/video]
I was really impressed with how the DLC coating fared... Seeing a coated blade out-perform a satin finished blade in wear testing was fairly novel, and not at all what I expected! I figured the satin blade would do the best in wear testing and then not so well in the corrosion tests, but as you saw that was not the case at all!
If you guys have any questions about the coatings or any part of the testing/application process please let me know! Obviously I love chatting about this stuff, so be warned I may talk your ears off about it
-Aaron
-Aaron
