Vietnam Tomahawk Review
Andy I received the Nam hawk from your fine firm the American Tomahawk Company and here is the review I promised you.
The initial inspection of the hawk shows a no compromise CQB tool the five cutting edges are well ground and show equal grind geometry. The edges are sharpened to a fantastic working edge without the fragileness of a razor sharp grind witch in my opinion is in appropriate on a high impact defensive / offensive tool. The lower cutting edge on the hatchet has a slight belly to it that really adds to it cutting ability the sharp corners on the blade penetrate like a stiletto leaving a tryangulare wound channel. The spike end has the bottom of the spike sharpened and has a slite angel to it to alow the spike to cut a path out to prevent it from lodging in it’s own wound cavity.
Testing supplys were obtained from Goodwill and the local butcher shop and consited of a rack of beef ribs and a leather jacket.
The first test was to see the penitration of the hatche head on the ribs with the leather jacket covering then. I hung the ribs on a closes line so they would be free swinging. Using the hawk in a downward swinging motion hitting the ribs with the upper tip of the blade it left a one-inch penetrating wound chipping the upper rib and left a 8th of an inch dent in the lower rib. The next test was to hit the face of the hatchet directly on to the ribs the leather jacket was penetrated completely leaving a gash in the two ribs about a 16th of inch in depth. The next test used the lower corner and cutting edge this penetrated the jacket hit the upper rib about center and shattered it cutting cleanly thru the connecting tissue and braking the next rib in half then using a downward pulling motion it cut it’s way out of the rib cage and jacket leaving about a seven inch gash in the jacket and a four inch cut in the rib cage. The final test of the cutting head was to go into the ribs parallel with the ribs using the lower cutting potion of the blade it completely severed the leather jacket and connective tissue this left a nine inch long cut in and by angling the handle up or down the sharp lower edge would bite the ribs and wedge it’s self there making it a formidable control tool and by further rotation of the handle will leaver the ribs apart braking one of them and doing massive tissue damage.
The spike end will shatter or chip any rib it comes in contact with and if it misses a bone by using a prying motion it will cut it’s way back out of it’s wound channel leaving a 2 to 3 deep wound cavity that is about 4 inches long once the spike is in use the tool like a claw hammer to maximize the hawks effectiveness.
As a utility tool it works well to cut steel banding and pry open wooden crates. I used it as a climbing aid in trees and am very confident of it’s strength. . As for it’s throwing ability I do not know for I tend not to throw away my weapons and as far as chopping wood I would prefer an axe.
How did the hawk came thru, well it came thru with flying colors the blade darkened from the blood but showed no chipping or dulling through out the testing and no loosening of the head at all. This is a first rate combat weapon and will prove to be a fantastic partner.
Thanks Andy for bring back a wonderful combat weapon.
Respectfully
MMURRAY
Thanks for sharing the results of your testing & welcome to BF. I couldn't agree with you more on the quality & usefulness of this great CQB tool. I worked a bit with mine last weekend & plan on doing more over the next 2 days. My uses to date, however, were more utility & fun (i.e., throwing) based than combat oriented. (I'll post my impressions next week.) I think your tests are an excellent testimony to the devastating effectiveness of this hawk. Thanks again for your fine review.
Great review! It confirms what I suspected would be the case from study of the design. Sure like mine.
I don't know about the rest of you, but I cringed reading that review. I sure would hate to encounter the business end of one of Andy's toys!
Cerberus.:cool:
MMURAY: Does your hawk have the armor piercing edge on it or the thinner, razor edge?
It has the armor piercing edge and was tested in the condition I received it with no touch up work to any of the cutting surfaces as I felt none was needed.
Wow. That's a devastating tool. I also cringed when I read about it.
Well, I just gave in and ordered one of these babies through Brigade Quartermasters. It will be my first tomahawk. I have been sitting on the sidelines for the past two months going back and forth on which one to get and talking my wife into believing that we actually need a tomahawk around the house. I tried requesting a specific serial number form Brigade Quartermasters, but they stated that they do not have that capability. So let's roll the dice. They said I should get it during the second week in August- I can't wait!!!
That is interesting work. Have you ever done anything similar with a large knife, I would be curious to know how it compared.
-Cliff
No Cliff I have not attempted this with a knife. I will certainly give it a try with a large blade what knife would you suggest. I teach CQB to operators and rape defense tactics here in Cincinnati. I an always looking for tools that can give my CQB students an advantage in there duties this is why I conduct the most realistic test I can, to develop a realistic expectation of the tools ability. If there are any suggestions for testing or techniques you would like tried I will try to accommodate. I was hesitant to writing part 2 of the review since it gets a little more graphic. I talked to Andy and he said go for it so I will have it written by Friday if all goes well.
MMURRAY, any decent large knife would be interesting, just to show the difference in performance as I assume it would be quite severe, based on some comparisons I have done between the ATC-spike and a few large knives.
-Cliff
