- May 12, 2005
A Sher Villager BAS that I recently purchased inspired me as an experiment to etch the blade with muriatic acid and then phosphate it while doing controller programming at a client's plating shop Friday evening.
This is the blade degreased in hot alkaline solution, then etched in 25% muriatic acid for five minutes:
The hamon is somewhat visible in the photo above, starting less than in inch from the tip, getting very wide in the belly, then tapering in the lighting glare to the edge about an inch and a half or so from the cho.
I held the blade in the 190F zinc phosphate bath for 20 mins, slowly "stirring" the blade around. After rinses and a hot inhibited final rinse followed by a 60 minute "cure" and oiling with Corrosion-X, I treated the unfinished satisal handle to several coats of Watco Rejuvenating Oil. The result appears below:
The dark unpolished and phosphated blade is really set off against the oiled satisal handle, and accented by the fittings and the Sword of Shiva brass inlet. This BAS is the sharpest HI blade out of the box that I've bought to date; even after the acid and phosphate I can shave my arm and I haven't put steel or stone to it yet. Darned thing looks too nice to use now, not so?
Noah
Noah
