Erin Burke
KnifeMaker...ish
- May 19, 2003
I am working on a 1080 guard that I wanted to artificially age/darken. I'd heard of some folks using a mix of vinegar and bleach to develop a nice patina. So that's what I tried... a 50/50 mix of white vinegar and bleach. I took the mix outside (because I'm always concerned about fumes from unknown chemical mixes). Below you can see some before and after shots from this process.
BEFORE
AFTER
The AFTER shot illustrates a VERY FRUSTRATING problem that I am having. The patina is forming very unevenly. In fact, one small strip on the edge of the front face of the guard (easily seen in the photo) will almost not react to the chemicals at all. At first, I had assumed that there was some oil or grease in this area that was inhibiting the process, so I re-sanded, cleaned with acetone, with soap/water, and with rubbing alcohol and tried again... with the exact same results. I have sanded repeatedly. I have rinsed and washed with everything under the sun... still that same spot will not react to the vinegar/bleach. I am using a hooked section of wire to dip the guard in the mix and agitate. Any ideas on what the problem might be and how to resolve it?
BEFORE
AFTER
