- Feb 3, 2001
Alright, I started messin' around with vinegar and carbon steel knife blades.
First I just cleaned with soapy water and final wipe with alcohol and dipped it in a glass of vinegar and let it sit for about 1/2 an hour, when I pulled it out and saw how even the patina was I had an idea and masked off a little spot and repeated the process after polishin' off the coatin'.
So now with some scotch tape and a wharncliff Case SBJ I cut out a crude flame and left that part covered then put it in the vinegar again for about an hourm took it out and rinsed with cold water pat dry and then apply a wipe of oil to coat it, here's the result, I will do this a little longer and a different pattern like maybe a scroll or somethin' anyway here are the pics, keep in mind this was done in a hour so the longer the exposure the higher the contrast.
If anyone would like to try and post yer results here, I'd really like to see 'em, all ya need is a cv or similar high carbon steel blade, some tape, a pointy knife to cut yer pattern, some vinegar and a little imagination, have at it.
This was the first time with a longer exposure.
