Vision aids for use when sharpening?
I was curious what kind (if any) vision aids you guys use during your sharpening process? Things like magnifying glass, bright lights, Lupe's etc.
I have a 10x lighted Lupe that I use to inspect the machined surfaces of some of my machining projects occasionally... it also gets a lot of use looking for that illusive metal sliver embedded in my finger.
I was thinking more along the lines of one of those lighted large magnifying glasses on an adjustable swing-arm. Seems like with something like this you could use it during the sharpening process and not have to set the knife down to pick up a magnify glass. You could take few strokes and shift over a bit for inspecting it under the glass... Or maybe those swing-arm glasses are not powerful enough in terms of magnification?
How about task lighting, do you have some specific lighting set-up near your sharpening gear?
Wayne
I have an inexpensive magnifying hood that I wear on my head (you'll see jewelers using them a lot.) The hood swings up out of the way when you dont need it. I really like it and use it all the time. With my old eyes the more light the merrier so I have fluorescent shop lights and spots in reflectors set up above the bench.
Wayne
Magnification and good lighting are essential to most precision projects.
If you learn to hold proper angles with a stone you should be able to sharpen in the dark. This takes some practice, but once you have the tecnique mastered it's easy.
Bill
I have a lighted magnifying glass on a swing arm like you mentioned. I dkon't know the power of magnification but it may not be enough for you. It does fine for my other projects with wood and helps with sharpening also. I'd reccomend one.
Best yet, combine the marker and the 10x loupe.
I use a black marker, but that isn't important (color), as long as you can see, with the loupe, what you are or aren't taking off and what's happening.
Rob
I use oil....yes oil.
I work up a little grey slurry of oil on the stone, and drag the edge across it, "loading" the blade with a bead of the slurry. Due to surface tension, the slurry will stay put right above the edge. When I lay the knife back on the stone and slowly lean it to the correct angle, the surface tension of the oil slurry breaks and runs off onto the stone, and I drag across.
The oil loads itself everytime you make a pass so you can repeat it.
hope that made sense... I've been sharpening for a long time, and that's just a little technique I've developed. I can sharpen without oil too. I just lean my head in right up close to the stone...:p I also pay attention to how the light plays off the polished edge to get the right angle.
