Visit to an old mountain forge
Yesterday I visited an old mountain forge. It's placed (obviously) along a small stream. Downhill from it, another 4 forges were placed along the same river, in the XIX century.
The first peculiar thing is how the anvils were fixed. They seemed to use small anvils, 40 pound or so, even for very heavy work, looking at the tongs that were in place. The fact is that the anvil was placed, much like a stake anvil, in huge rock lumps projecting from the ground. Basically, each anvil was permanently and solidly affixed to the mountain itself, making pointless the use of a larger anvil.
The waterwheel was connected directly through its axle to a big gear, with teeth affixed singularly with pegs, so they could be easily substituted.
A secondary gear connected the bellows and trip hammer. Everything could be operated by the sitting place in front of the forge.
A second gear connected the mill on the second floor. A weight was placed in the wheat hopper, and was connected through a piece of string and some pulleys to a small wheel on the forge floor: when the hopper was empty, the small wheel reached the top of its travel, signalling the smith to add some more grain in the mill. This way the whole forge + mill arrangement could be handled by a single person.
Another peculiar thing was the water blower: it's a stone box, about 3'x3'x3', with three holes on the top, a big square hole in the front, which was closed by a wooden hatch, for maintenance, and under this a smaller, rectangular hole.
Water mixed with air was collected by a wooden pipe from the stream and entered from the bigger hole on the top. The water level inside the box was slightly above the exit hole, in the front wall. This way, water exited the box, but air could not exit the same way, and was forced out of the two smaller holes, to be sent to the tuyeres of the forges along the stream.
All these places were originally reached via small stone slabs affixed in the side of the mountain, like stairs. The slabs were about 1 square feet... :eek:
I've seen videos of and old Italian forge , perhaps it's the same one . The 'albero' [shaft] is really an 'albero' [ tree trunk] !! Can you give us links to such videos ?
There are several old forges in Italy. The most famous probably is the old hydraulic hammer at Ome, near Brescia.
In Italian is called a "mule head" hammer, due to the resemblance of the head of the hammer to a mule head when viewed frontally.
In that area, in less than a square mile there were more than a hundred forge shops, due to the abundance of small streams.
The difficulty of using a water hammer is that while on a traditional mechanical hammer like a Little Giant and similar you can control both force and frequence of impact, on a water hammer like these you have very little to no control at all.
One of the smiths of the Ome hammer told me that all he can do to control the hammer is shouting to his daughter, who stands outside by the water trough, to open or close a little more the water inlet, and that's it. :D
The hammer has to be used frequently, because if the wood remains dry, it will crack. As long as it is kept wet, the main parts can last centuries.
Here are some links I found (in Italian, sorry).
http://www.youtube.com/watch?v=XcWpKj-AG94
http://www.youtube.com/watch?v=V1OoJkxzRWg
From here you can access many other links. You cen see how the forged iron buckets in these examples.
Keywords are:
Maglio ad acqua
Maglio idraulico bresciano (caution: maglio idraulico may eqully define an old water weel hammer and a modern hydraulic maul)
Maglio di Bienno
Alarion,
Thank you so much for sharing both the videos and the explanation. The history and heritage of the smithy is one of the things I love most about making metal things.
