Field Report Chopping Test on Trishul Decker, Hanuman, 21 Gelbu Special, and BirGorkha Tawar
Wayne Lau
(The Big Kahuna)
This FR was meant to be a test of the chopping efficiency of my HI user knife/khuks/sword. Though few in number (compared to other forumites), they cover a wide range of sizes and designs. This was not meant to be a head to head test of two similar khuks. It was to compare the chopping usefulness of khuks of different sizes and blade types.
First picture
The HI products compared are:
Top: Trishul Decker 13 inches long, 1 lb weight (16 oz), point of balance 1.5 inch from top of hand. An experimental knife by Kumar that doesnt seem popular enough to be a catalogue item. Very thick, weight forward blade. Full tang but in a thin, long handle. With a beautifully carved handle and curved horns on the guard, the knife seems more display model than user (which turned out to be wrong). I like its long handle and heft (Im 63 and weigh 290 lbs so I prefer blades a touch on the big side). Mainly used as a hiking knife. Knife came dull out of the box and was made duller by use. Edge is clearly visible. Couldnt slice cut a sheet of newspaper without tearing. Didnt sharpen it before the test (lazy!), but wanted to see how it worked as a chopper in a pinch.
Second: BirGorkha Hanuman Dui Chuirra, 18.5, around 2 lbs (32 oz), POB 5. Similar to but lighter than the large 18-20 inch Ang Khola chopper. Handle is unusually thick which fits my bear paws well. Comes with a full tool set and a bulky scabbard. It isnt meant for belt carry (but with my fat size, it hangs on a belt just fine). Sher made. Used as base camp khukuri/axe. Sharp.
Third: 21 inch Gelbu Special 21, around 30-34oz (dont have a scale), POB 5.5. Large version of Palas recommendation for best all around Khuk. Large sweet spot from belly to curve. Main carry khuk for clearing/cutting trails, clearing underbrush around overnight hammocking spots, cutting shooting lanes. Kumar made. Can be belt carried but may jab leg. Usually carry on Terry Sisco made baldric. Sharp.
Fourth: BirGorkha Tawar 28.5, around 36 oz. POB 5.5 (held close to guard). Actually a Bura made sword. But used as an oversized machete to clear thick brush/jungle in hunting. Will be taken along in that future boar hunting trip with dogs and knives for when I chicken out of using a knife. Carried on side baldric but can be put on the back Conan the Barbarian style for Hollywood effect (only problem is avoiding cutting ear off when pulling or sheathing blade J ). Not usually thought of as a chopper but wanted to see what it could do anyway. Sharp.
Note that except for the relatively small Trishul Decker knife, weight and point of balance of the khuks and swords dont rise much even though length increases from 18.5 to 29. So from the point of how difficult it is to carry (versus how well it chops), the bulkiness of length may be more relevant than weight.
The stroke style used in all tests are an easy machete style stroke. Upstroke: each khuk is lifted to just above ear level (this is most of the work). Khuk is held by relaxed grip with only first finger and thumb (and maybe middle finger). Ring and pinky are free so blade falls behind back. Down stroke: grip is still relaxed. Soft closing of hand rotates blade up. Then hand and arms are loosely dropped (ideally no downward force) and falling blade is guided toward target. Just before reaching target, hand closes and wrist snaps blade into cut. Grip is still kept loose so that any handle vibration or shock (rare because downward force is minimal) can be felt but does not affect hand. Disadvantages of this stroke: a) force relies on gravity of blade and last hand/wrist snap, so power is much lower than a normal down stroke with force, b) loose hold on hand may let handle slip forward on wrist snap especially if wet. Advantages: a) accuracy - out of over 300 strokes in test, only 2-3 bounced before biting, b) ideally, only hard work is lifting khuk during upstroke, so many strokes possible, and c) hands dont get tired as quickly (my hands got more cramped cleaning, polishing, oiling the blades, and typing this FR after the test).
The test site was a roughly 40 ft. tall jungle tree which just fell across a sidewalk. Wood is harder than pine (cant make a fingernail impression). But much softer than fruit hardwood (cherry, etc.). Best guess is that it is somewhat softer than oak. Although all cuts were made against the grain, this wood split easily along the grain (see below). The Tawar is shown on the site pic below for scale.
Picture 2
Two tests were made, cutting a 2 inch diameter limb and a 7-8 inch diameter trunk Every effort was made to use the same limb in each test (though splitting limbs did cause two limbs to be used in the 2 inch diameter test). The khuks were held in relaxed gloved hand which naturally found its place on the handle after a few strokes (standard operating procedure). A bit of chap stick was put on sides and edge to protect blades from tree sap and help lubricate cuts.
