recently got a SOG Vulcan folder, and yesterday it stabbed me, pretty bad pinch and bleeding, the works.....
had it in my backpocket, even close the side to prevent opening. fumbling to get it out of my pocket and the tip found its way into my thumb, bled like crazy
i found out that the blade hadn't even opened from the handle, but just that taking hold of the knife with little force is enough to drive your thumb into the tip in the closed position
thing is i noticed: when closed the tip is only 'shielded' in the handle, within the extended liners-part at the butt actually, by a mere 2mm margin (!). it's almost inevitable to feel the tip while closed. i think this is a design flaw, which is very unfortunate since all the rest of the knife is truly awesome
try this if you handle one: hold it upsidedown (tip up, as if clipped to pocket), closed, feel with your index finger at the extended liner, with the 'sog'-name cutout, and feel between those liner parts. that's the tip rubbing your finger. do it hard enough or 'just right' (just wrong is more like it.....) and you'll ge stabbed
i mean c'mon SOG! only a mere 2mm of tip enclosure while closed? that's just way too little. the fact that the knife also has a smooth arc-lock and carries tip-up doesn't actually help this problem.
are there any tricks to solve this, apart from grinding down the blade a centimeter.....?
i was really psyched when i got the knife, cool assist flipper, great grip, nice droppoint recurved swedge blade, but this is really somewhat of a bummer. i'm now scared of drawing this knife from the pocket.....
regards,
denn
regards,
denn
