- Apr 13, 2007
Hi,
I've got several SOG knives. My experience with the SEI taught me as much as I know about torquing the screws in the handle around the pivot and arc-lock to get the knife to stay in the handle and not "shake out".
The blade on my new Vulcan is quite a bit heavier. It is breathtaking the way it sweeps from the thickness of the spine to the extended hollow grind, but even with all that weight removed, it is heavy for a SOG clip-on folder. It has more of a mind of its own about overcoming the arc-lock's retaining force. The blade is too easy to shake out of the handle for my taste, even sitting at the bench making microadjustments. Also there is one less screw to fool around with than on the SEI.
Is there a proper sequence of tightening, a thicker stickier lube, or some way of keeping the beautiful (you can't tell anything from the pictures - this thing is go to the moon slick and hypnotizingly interesting in its geometry - a knife nut's dream) blade tighter between the scales and still fairly easy to open and close?
Somebody wise me up. I'm certain that I'm doing something wrong.
walkin_mark
walkin_mark
