I cut a slot into a cheap handscrew clamp for gluing up wa handles. This has worked much better for me than a similarly modified quick clamp or the vise and slotted bench dog I tried before. The hand screw can be adjusted to apply even pressure across the entire joint. I set the back screw to the length of the handle stack before I apply glue and the front screw to be a bit more open. The clamp is pretty stable sitting upright on the workbench. After everything is epoxied up, I push the handle together lightly by hand and cleanup the initial squeeze out, then put the handle in the clamp with the blade in the slot and tighten the front screw a bit. I then adjust the front and back screws to get even squeeze out across the joints. After about an hour, I pull the blade out, but the time will obviously depend highly on the epoxy used.
The pictures below show the modified clamp. I cut it on the table saw by clamping the clamp to the back fence of a cross cut sled with a couple of 2x4 offcuts as additional spacers to avoid cutting into the second clamp jaw. I used three cuts with an 1/8" blade with a 30mm depth of cut. I would probably make the slot a little bit taller if I did it again. I think the clamp I used is this 12 in Handscew Clamp from Harbor Freight that costs $10.99.
So far, this is the best method for gluing up wa handles I have tried. I'd be interested to know if any of you have a better way of doing it.
