It’s a north south thing (one scale is ever so slightly higher than the other) with the scales. loosten up the pivot, the body screws, and the pocket clip screws. Then place a folded bit of paper on the side of the blade the blade is leaning towards (smaller gap). Then on the greater side gap, press the scale up towards the pivot, while simultaneously pressing the opposite scale towards the butt. Squeeze the scales together, not letting the adjustment up then tighten-but don’t over tighten the bottom two (butt end, both sides) body screws. Then the pivot screw, snugly. Pull out the paper. And check your centering. If good, tighten the remaining body screws-then the clip screws. If not loosten the screws again, slightly...and dial it in (pressing up on one scale, down on the other) till the centering is where you want it. Then slowly loosen the pivot screw, until the blade will be pressed shut by the rocker lock-even if only pulled up slightly-the spring still pushes and holds the blade closed.I've owned three Frenzy's. All had centering issues. I tried everything, even taking them apart and I still couldn't get them to Center Properly. Fantastic piece to carry though. Super light, disappears in IWB.
With a blade that long though, its a super challenging thing to be able to get it to center. My experience, YMMV, That long Blades generally have more of an issue with Centering.
Congrats on your new piece. Great one.
