Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I just poked my thumb with the tip of the tanto while hand polishing it,so I thought I'd take a break while the bleeding stops.This set is san-mai over a laminated core of 52100.Habaki,seppa,tsuba,and fuchi will be mokume.The collar on the tanto shows the mokume pattern fairly well.They are hand sanded to 400 at this point,with the tanto given the first prepolish.The wakazashi has many hours of sanding to go.A trick I came up with is to polish with flitz/simichrome after each grit.You will see the areas that are not done yet clearly,and the next grit will take less time - try it you will be amazed.The wakazashi will have a traditional tsuka,with same' (ray skin) and silk wrap.The tanto will have a fixed tsuka with same' and silk.Sayas will be yellowheart with black lacquer coats.I hope to finish the tanto this weekend,and the wakazashi in a couple of weeks.
