- Apr 18, 2011
Hey guys!
I am currently working on a large bowie for a good customer of mine, and I have been snapping pics along the way. It is "only" stock removal, so some you may or may not be interested. I am almost done now, but I figured I would share what I have so far. I don't have pics of every step, but you will get the idea.
It will take a little while to put all of the pics together, but I figured I would get started.
This is going to be a fairly large Bowie, to his loose specs. The blade is appx. 11" long and 1075 (my favorite for a nice hamon). It is a big bellied blade with a curvy clip.
Here is the blade rough profiled.
Getting the clip roughed in. It can be tricky on a curved clip.
Here the blade is rough ground and ready for Heat treat.
Here it is with the clay applied. I normally use Satanite, but I was trying this other stuff out on this one. It has a very thin wash on the whole blade, and then about a 1/16" where I want the "soft" areas to be.
Ok, so hardening and tempering went very well. I quenched in parks 50. No pics, sorry.
Here I am cleaning up the clip. I want to keep nice crisp lines, this is easiest by hand.
Off the grinder and on to hand sanding. I wish I was a better grinder, I could spend less time hand sanding.
Here the blade is at about 120 grit, and you can already see the hamon popping out.
Here I am cleaning up the ricasso/choil area. It is important to keep everything nice and square here. I find it easier to use edm stones in here.
And the other side of the blade, it is now at 220. Only 7 more grits to go!!!
More pics to come........
