- Mar 2, 2010
For most of the blades I intend for really hard use, I prefer what would be more of a "Villager" finish over the high gloss finish many come with from the Kamis. Above you can see the Parang I recently bought, on the top it is as it came from HI mostly (I had used it a bit prior to the picture so there are already a few scratches) and below you can see the more satin appearance it has now as well as the way I did the deed. I used a Scotch Brite pad, the non-sponge side, and I then simply went along the blade with it in a single direction until I had the look I was after. This took me about a half an hour.
I find this method to be the best. Much better than using sand paper of any grit because the Scotch Brite is the right hardness and "grit" size, easy on the hand and easy to grip and use plus they are cheap. It doesn't really take much force either, you just press it down into the blade and make sure you only go in one direction. If you go in swirls or back and forth, I have found it makes it a lot less attractive looking but it will still knock the shine off of the blade. Try to keep your strokes parallel to one edge or the other to make it look best, on the Parang I went with the top. Don't stress out on making it perfectly parallel. This variation is what will make the satin look you are after but do try to stay in the one direction and do try to stay relatively parallel as you work.
This is an easy way to make your blades look great and you can stop stressing out about them getting a scratch on them once you have done this to them. Of course some of my showier blades remain High Gloss and I can maintain those as well if they get scratched but that is another thread. Hope this is helpful.
