From what I've been able to glean, the least expensive way to upgrade from a single-speed to a variable speed grinder is to get a cheap 3-phase motor and a VFD.
Could someone give me an overview of what I should be thinking about in pursing a setup like this? I've done some searching, but most of the VFD-related questions are very specific, and I'm looking to understand the big picture.
I'm currently running a 1-hp 1750 rpm motor from Grizzly at 220v. I'd like to get some more horsepower (mainly for platen grinding while removing forge scale from razor blanks), but what I'm most interested in is the adjustable speed. I'm hoping to spend $200-$300, which seems doable.
What are some good options as far as VFDs? What is involved in hooking this up? I'd be comfortable doing basic wiring, but some of the posts mentioned capacitors and such.
From what I've read so far, it sounds like I should be looking for a 3-phase TEFC AC motor in the 3-5 hp range, and a VFD that is rated for the (current? horsepower?) motor. It sounds like I'll get a little more than half of the rated horsepower by running it on single phase juice. Would a 1750 rpm or 3500 rpm model be better?
Are there other avenues that I should explore as well?
Thanks,
Josh
Thanks,
Josh
