I recently purchased a Gerber LMF ASEK, since recently I tend to go for pilot knives.
The following pics show the Gerber LMF ASEK in comparison to the Ontario ASEK:
In sheaths
Now what seems important info for me to share is this:
What you see there, is what is commonly refered to as the glass breaker pommel of these ASEK knives.
The Ontario's pommel works perfectly as a glass breaker. I had the chance to test this on several safety glass windows, and it always did the job with the first hit.
Where the Ontario worked flawlessly, the LMF ASEK failed miserably. I could not break a single safety glass, even after several hits with considerably more force than with the Ontario ASEK. Maybe even more force would have helped, but I was at the point, where I worried about my hand and arm when using more impact force.
NOW: Gerber NEVER said it would be a glass breaker. The intended use is for PLEXIGLASS. And guess what: I bought some Plexisglass (6 mm thickness), fixed it thightly and SUCCESSFULLY used the LMF ASEK to break it.
SO: Though you would think a tip is a tip and both pommels should work on safety glass alike, they do not.
If you keep the Gerber LMF ASEK in your car, and you intend to use it as a glass breaker in case of an emergency, be warned: IT MAY NOT WORK.
Any similar experience? Did anyone else test the LMF on glass?
Correction: It does work, I was wrong. See below
In sheaths
