- Dec 4, 2005
Hello. I have been reading this forum off and on for awhile. I finally decided to post.
I moved to Hawaii some time ago. I used to do welding projects, but steel is very expensive here. I have decided to try my hand at knife making (less steel needed, and probably can be had for free). While reading about this on the web, I found info about simple forges and became really interested.
I wanted to do some simple experiments by digging a pit in the ground and heating some steel. I looked but can't find real charcoal on my island. I had to use Kingsford briquets. I had a hair dryer duct taped to a pipe for air.
I got the charcoal going. The hair dryer seemed to supply enough air, but the damn thing kept shutting off. Must be an internal circuit breaker or something. I ended up using the outlet of a small shop vac. It supplied way too much air. I still got the steel red hot, and a magnet wouldn't stick to it. I was also able to bend it very easily with pliers.
I am still pretty clueless. I see everywhere that you should not use charcoal briquets in a forge. Can someone tell me exactly why this is?
This was alot of fun. I can tell I am going to be hooked.
Gregg
Gregg
