- Oct 22, 2020
Last night I normalized an Old Hickory Hunting Knife blade, I want to change the handle scales to the old traditional 6 pin configuration but had to normalize to be able to drill new holes through the tang for the pins. I wrapped the blade in stainless foil and took it to 1650F in my Evenheat oven. After a 10 minute soak I took the blade out and buried it in a bucket of wood ash to cool slowly overnight. This morning I took the blade out the foil and noticed it had developed a significant warp and slight twist. When I was looking at the normalizing procedure for 1095, which this blade is made from, there were no instructions on whether to put the blade in the cold oven and ramp up, or to get to temp then put the blade in like I would usually do for austenizing. I ended up putting the blade in when my oven was at about 1000F. Was the warping due to when I put the blade in the oven or something else? I know these are relatively cheap and simple knives, stamped out of strip metal so I also wondered if the warp could be from residual stress during manufacture. Just looking for some advise and knowledge on this matter. Many thanks.
