Thanks! I don't have G10 liners, so I guess I'll just work with the lack of material.They have to be sanded flat at least on the tang side. Consider a liner material between tang and scale to add thickness back at assembly. I prefer G10, for the color choices. Micarta is also a good choice.
Trying to flatten them by clamping or some other mechanical means will only result in re-warp down the road. And that ain't good.
I use epoxy and brass/stainless steel pins, so probably wouldn’t work. Thanks though!If the handles you make from them are securely attached with mechanical fasteners, the warp won't matter.
I also like using vulcanized fiber with wood, and it's even cheaper than g10 and micarta
Thanks for the tip! I’ll look into that, eventually. I just started making knives a few months ago, so pins + epoxy is good enough for the knives I’m making right now.Maybe this is a Good reason to improve your fastening techniques.
Not telling you how to do it.....but
I'll probably never buy a glued/pinned knife again. Too many failures.
*not talking peened in Properly reamed/tapered holes. Those are fine. Especially in light duty.
But so many just glue, and grind.
I don't personally think That's good enough.
