- Mar 19, 2007
1) Use a bag wash that is specially made for sleeping bags - or some Woolite. You essentially want a non-detergent style soap that does not take the oil off the feathers.
2) Use a front loading washer. Put it on the delicate cycle.
3) Set the washer to spin cycle a few extra times. If you can - set the spin cycle on the slowest setting.
4) Use a front loading drier - set it on low (delicates) and run it for about 15 minutes. Take the bag out and try and fluff up the bag. Do this every fifteen minutes until the down stops clumping up and is fluffy.
5) Some say that tossing in a few clean tennis balls into the drier will help fluff up the bag.
6) Take your time on the dry cycle - you want to make sure it is dry. As long as the heat is not to high - and you don't let the bag sit (make sure to pull the bag out while the dryer is still tumbling) - you can let it run for a very long time.
I ran mine for almost 3 hours until I was satisfied.
7) You don't have to do this very often - but you can return a lot of the loft in a bag and take the smell out.
TF
TF
