- Apr 23, 2002
Washington State knife law proposed change
As a heads up for Washington State residents, HB 1006 was prefiled for this session. While it seems to remove Daggers and Dirks as specific dangerous weapons, it adds language limiting blade length to 3.5"
Might be worth a call to your local representative's office. With a huge budget hole, we could probably not waste time making new bad law.
Not a clean cut and past. Here is a link to the original filing
http://apps.leg.wa.gov/billinfo/summ...2011#documents
Red would be stricken, blue would be added.
1 AN ACT Relating to knives; amending RCW 9.41.250; and prescribing
2 penalties.
3 BE IT ENACTED BY THE LEGISLATURE OF THE STATE OF WASHINGTON:
4 Sec. 1. RCW 9.41.250 and 2007 c 379 s 1 are each amended to read
5 as follows:
6 (1) Every person who:
7 (a) Manufactures, sells, or disposes of or possesses any instrument
8 or weapon of the kind usually known as slung shot, sand club, or metal
9 knuckles, or spring blade knife, or any knife the blade of which is
10 automatically released by a spring mechanism or other mechanical
11 device, or any knife having a blade which opens, or falls, or is
12 ejected into position by the force of gravity, or by an outward,
13 downward, or centrifugal thrust or movement;
14 (b) Furtively carries with intent to conceal any ((dagger, dirk))
15 knife having a blade longer than three and one-half inches, pistol, or
16 other dangerous weapon; or
17 (c) Uses any contrivance or device for suppressing the noise of any
18 firearm,
19 is guilty of a gross misdemeanor punishable under chapter 9A.20 RCW.
p. 1 HB 1006
1 (2) Subsection (1)(a) of this section does not apply to:
2 (a) The possession of a spring blade knife by a law enforcement
3 officer while the officer:
4 (i) Is on official duty; or
5 (ii) Is transporting the knife to or from the place where the knife
6 is stored when the officer is not on official duty; or
7 (b) The storage of a spring blade knife by a law enforcement
8 officer.
--- END ---
2 penalties.
5 as follows:
18 firearm,
p. 1 HB 1006
8 officer.
--- END ---
