The G-Shock would be a good choice. There were a few solar models with problems (mostly the GW-300). Some thoughts now seem to be leaning towards Panasonic having had a bunch of bad 1616 cells. The problem should be fixed now. If that would still concern you, there are other solar models using the 2016 rechargable cell that have no record of any problems.
There are plenty of display options. The combo displays are nice, but the digital parts are ususally small and dont display all the desired information (time, seconds day/date) and such all at once, you have to cycle through. I have a few of them, but if you need easy to see at a glance I would go with all digital.
The radio control is nice, but as stated above it is dependent on location.
This particualr model is nice (available in black if you need it). Solar, not radio controlled, timer, alarms (5 of them) and all the usual gadgets.
This is a combo display, solar and radio controlled. I like it a lot but the digital display part is small and shows very limited info at any one time.
This particular model is very popular. There was a guy at WUS who has tested his to extremes. He has frozen his in blocks of ice, thrown it against walls and most extreme was tossing it off the roof of a 25 floor hotel onto the concrete below. The watch still works and only shows a few scars on the outside.
Probably one of the most desired models if the Frogman. The Triple Crown model is the current version. It may go a bit over your 150 limit, but IMO it is worth every penny. It is solar with a large storage cell and a nice easy to see display.
