Yes. The problem is that I don't remember every forum I subscribed to...Do they show up if you re subscribe?
You can change that in Alert Preferences.I had to do it manually as well. Unfortunately I get alerts every time someone posts a new thread, though!
Mine got lost, but no biggie. I rebuilt them in five mins.
I went through again and chose my new 'watched forums'. It's simple: Go through the forums again, click on one you watched, and once in, on the RH top is a small tag: 'Follow Forum'. Done.
Sorry. It's slightly more complicated.I lied, it didn't work.
What box/s should I untick?
Go to your Watched Forums page. Check the little box next to a forum. There's a drop menu that says "With selected" You can enable or disable alerts. Good luck.
Aha! That did the trick. Cheers![]()
If you are using the Flat Awesome styles there's nowhere near as much scrolling now.I never used this feature before, because it was easy enough to get to the specific forums I wanted; but, with the amount of scrolling it takes now, I thought it might help.
