- Feb 28, 2007
My maxpedition pack has the compartment in it for a water bladder/drinking hose/bite valve but it took well over a year to finally get myself a bladder (Playtpus basic one with 2.0 L capacity). I've always used a water bottle holder attached to the side of the bag and that seemed good enough. However, on my last trip in the heat I found myself needing and wanting to cart in 4L of water. So I'd lug 3L (1L nalgene in bottle holder + bladder) on my back and usually had a disposable water bottle in my hand.
Anyhow, this was the first time I tried hiking with the bladder and really took a shine to using it. Admittedly, the water did taste a bit plastic-like which I attribute more to the hose than the bladder itself but that seemed to go away after a couple of refills. Threading the bite valve through the D-ring on my pack keeps it in place and sometimes I gave myself a bit more slack and kept the end tucked under the sternum strap while walking. That worked at great for ready access to the bite valve on the go.
What I didn't realize is how effective you can draw the water in. The pressure on the bladder from being compressed against your back by the pack makes the water almost squirt into your mouth when you depress the bit valve. You can also pretty much suck out all the water up to the last ounce or so. Very impressive. I found during my hiking, I would drink more regularly and more often. I did go through water faster than I probably would with just my regular water bottles.
Some of the cons were that its hard to monitor how much water you have left since there seems very little indication when drinking the water until you hit the air-bubbles when its empty. There was also a couple of occasions where I transferred water from my bladder into my water bottle. Not that it was supremely difficult, but the valve wasn't very conducive to this and I ended spilling some of the precious stuff during the transfer.
Anyhow, I thought for a long time that the bladder system just wouldn't be for me. Now that I've used it, I think otherwise. I still like the versatility and flexibility of having a water bottle with me but incorporating both into my hydration system seems reasonable. Even if I don't need that much water, carrying an empty bladder in the designated compartment comes with almost no cost and I can effectively process and store a larger volume if I need to. Only wish my bladder came with a separate cap for the bladder apart from the hose/bite valve.
Anyhow, just some rambling thoughts by a skeptic on this piece of kit. They are well worth the $20 for a set-up! Kind of wish I went for the 3L model for its capacity in hindsight.
