- Feb 9, 2014
Hi Guys,
I was looking at utilizing either the Jet or Tormek water cooled grindstones for secondary bevel grinding onto carbon steel knives (possibly full thickness and hardened), but research seems to yield that they:
A.) Will not have enough power to remove material efficiently,
B.) Have stock stones that will wear away quickly if used as a primary means of bevel grinding,
C.) Probably won't have the width to adequately stabilize longer blades if utilized for freehand grinding.
Mr. Apelt had told me about his plans to fabricate a modern Kaiten Toshi (rotating Japanese water stone,) and I have seen a few other plans online, but is there a viable, small (8-10in diameter) water cooled grindstone that would be suitable for secondary bevel grinding? Is it feasible to swap out the Tormek or Jet motors with something more powerful? How about retrofitting an existing, more powerful grinder to take a Tormek stone? Will the Tormek specialty stones make them more useable for this task?
I have thought about water cooling a belt grinder, but that seems messy and probably expensive, as I would want to build a more substantial grinder if I went that route. Any thoughts on any of these topics?
Thanks,
John
Thanks,
John
