Yes Sawyer make a Nalgene type bottle with either a 5 log filter or a 7 log purifier depending upon your needs or wants. The bottle set up can be used with or without the filter if you don't want to mess with a filter (assuming you purify the bottle in/outside first!)
They both work but you'll suck your face off to get a decent drink from the purifier. It is is possible obviously to get a drink from the purifier but it a slow process. The filter is much easier. So if you only need to filter and not purification then it is a good set up. I have both. I do use the purifier with a 5 gal bucket gravity feed system which is portable, realtively inexpensive and highly effective. For it I'm in no hurry so I let it slowly refill my Nalgene bottles, Camelbak or whatever...
If you buy the Nalgene type bottle set up from them, then you can take the filter or purifier out and use it on a 5 gallon gravity fed system like I made. They sell a 5 gallon kit but you can make the same thing at home with a couple inexpensive parts from a hardware/plumbing store and then have double duty. I try to buy gear that gives me maximum flexibility rather than highly specialized "one-time" gear.
I've been very pleased with my double duty set up. I find they last an extremely long time - pretty much indefinitely if you maintain it well and don't let it freeze etc...and when the filter or purifier gets too slow (plugged with bio gunk) I just reverse the flow or it comes with a flush adapter so you can hook up a garden hose and flush it out backwards. Once flushed it is reset to be used again. Sawyer puts a "gallon count number" on their product because customers demand this (they/we expect some expiration) but in reality there is no limitation as these units can be easily and quickly flushed and safely re-used over and over again - as long as we don't let them freeze etc. The one key is to pre-filter the larger "see-able" gunk" first so it doesn't plug the filter. I use my tee-shirt if I have too as a pre-filter for my bottle if I don't have anything else more sophisticated with me at the moment. This will give you much more mileage. But again, if it plugs, you've just got to be patient or flush it out at your earliest opp.
These filters/purifiers are the same technology used for Kidney Dialyses so this is high end stuff!
Nice thing is no batteries, no expiration, no drops to count, no nothing...a life long investment - once!
