- Jun 4, 2011
Thanks for looking, Justin
A good explanation on how you started out quenching in water. And it's a good place to start. If you can quench in water you can quench.Honestly, I've always quenched my blades in water. In the beginning, I took it as a cracked blade was just an excuse to forge another. Later, with experience, the failure rate came way down. Now it's pretty rare to crack a bowie sized blade.
You mention warping, but if the heating was even its usually not a big issue.
I've recently been experimenting with parks50, and have very similar amounts of warping. Usually I can grind out, at worst can fix while tempering.
The big difference is if I need to re-quench. With water, I've found that a second attempt at hardening will almost always crack the blade. But with parks I haven't had that problem ay all. For this reason, I'm trying to switch over to the parks, but I'm having some issues getting full hardening. I think perhaps I'm not using a large enough volume as I've not heard of others having this problem. Going to keep at it though as I've seen some very nice activity with the parks50 that I haven't gotten with water. Different, not better, another tool in the box as it were.
Anyway, Thanks. -Justin
