- Apr 5, 2000
I've spoken with a few members here about hamons and how much I enjoy working with them. I've decided to start doing more work in the traditional Japanese style, that includes water quenching blades. I've been doing some testing in water; trying to determine what I can get away with and what I can expect.
I wanted to pass a little information on to everyone, maybe it will encourage others to try their hand at hamon or even water
Here's the rundown of what I did wrong on this blade
and what others should consider when attempting their own quench.
1. The blade was too thin. I ground this blade with the intention of an oil quench. The edge was slightly under 1/16", I've found 3/32 to be ideal.
2. I "corrected" the sori too much; I quenched the blade in oil on the first attempt and got 1/8" drop. I could not correct the curve with controlled heating and some light hammering.
I decided to quench the blade for a three count, remove the blade for five, return to quench, then out. Well, the sori was corrected...over corrected. There is a 1/8" sori in this blade, a combined total of 1/4" curve out of a 9" blade. I'm convinced the long out of quench cooling is the culprit.
3. Keep the blade at a low temperature. I use a long soak and looow heat in the forge to bring the blade to austentizing. The hotter the blade is the more likely it's going to fail. A helpful hint is to HT at night; you can see the blade austentize if you watch closely.
I knew I was pushing this blade too hot, but I wanted to max out the sori...which was stupid. Even at the high heat the temp was still lower than "standard" knife quenching.
4. Be happy with your results. I quenched this blade three times. The first in oil, the second in water, and the cracker in water
. The second quench did not fix the sori, but the results were almost identical; four distinct habuchi, and more activity then I've been able to acheive before. So, instead of letting things be I went for broke, and that's exactly what happened.
5. When oil quenching blades keep the clay as thin as possible; the thicker the clay the more drop in the spine you'll see. Not to mention the spine will remain too soft.
Hopefully that little bit of guidance will help, or at least encourage, some of you to work in hamon.
Here's a shot of the doomed blade and its friendly reminders not to get too arogant
...I might feel bad if I didn't have two others ready to go
~In case you're wondering, this blade was only polished to 220 and dunked in my short ferric tank, I didn't waste too much time
. Also, the thick lines running across the blade are etch lines...
Matt
Matt
