I've tried all three. I've been sticking with windex for the last several months. My theory is that the surfactants keep the swarf in suspension better than plain water, so it cuts longer and cleaner, but it still cuts well. Soapy water probably works the same way, but windex is already mixed
Above 400 I switch to Mobil1. It suspends the gunk so well that I can scrub back'and'forth pretty aggressively with very little fear of "fishhooks". My final step (regardless of grit) is always dry with fresh paper, single pulls in one direction only.
I use water to 400 and baby oil over 400.. may try Kool Mist now that I have access to a lot of it for free.
Hah... it's funny, but I do the exact OPPOSITE of James, Darren (and Will) to some extent. I use oil (Mobile 1) for the coarse grits -- usually up to about 400 or 800 -- then switch to a thinner fluid (some sort of glass cleaner) for the high grits. I find that when I try to use oil at fine grits, my paper tends to "float" across the top of the oil instead of getting a clean consistent contact/cut. Interesting.
Erin
Maybe you're using too much. The first thing I realized when using Mobil1 was, it doesn't take hardly any. I have a lot more trouble with fishhooks when I use water or windex at the higher grits.
I have used all the above but now it is Kool Mist, which is a water based milling machine coolant. This stuff gives superior results. There is a rust inhibitor in it so you don't get rust on the blade surface. It holds the metal being removed in suspension. Its transparent so you can see what is going on on the surface of the blade. It can be purchased by the gallon and mixes at the rate of 1/4 cup per gallon.
I use it for all taping and drilling operations in the shop as well as for the Bridgeport.
Try this and you will be sold. Fred
I hear you about the hippie-zen-mumbo-jumbo stuff. That wears off after a hundred blades or so, though. I'm mainly concerned with getting the job done A) most imprtantly, right and B) on time.![]()
