what steel you recommend for prototyping, easier and cheaper to work with? thanks a lot on the informative input.No, CPM S90V is not a good choice to begin with.
It is very abrasion resistant, especially once hardened and tempered, and you will find it hard work to grind it, even with good ceramic belts. Some years ago I got to try working some CruforgeV, which is a LOT less abrasion resistant than S90V, having only ground O-1, ATS43, RWL34 and 12C27, and it took a lot longer to smooth out scratches than I was used to. If you don't have a grinder that can run specialist metal working belts, with enough power, its going to make your job way harder than you want.
S90V is also more expensive than other options, although not hugely more than some of the other CPM steels. Depending on what you want to test with your prototypes, it might be better do make them from something cheaper and easier to work while you get the design dialled in exactly how you want before you start talking to people to run batches in the premium material. If you have the design right, you can then make one off in the premium steel of choice to test the steel and how it works with a given edge geometry, without any of the other design factors getting in the way.
Best of luck whatever you decide
Chris
What sort of knives are you building? Do you need them to be stainless? Are you going to grind the bevels yourself and if so before or after heat treatment? Why did you pick S90v?what steel you recommend for prototyping, easier and cheaper to work with? thanks a lot on the informative input.
Golden
What sort of knives are you building? Do you anthem to be stainless? Are you going to grind the bevels yourself and if so before or after heat treatment? Why did you pick S90v?
As was mentioned S90V is not going to be great to work with. It is not known for taking and holding a fine edge and is not very tough. If I needed to cut cardboard or carpet it would be great but not a great hunter or bushcrafter or a chefs knife. There are cheaper steels also more versatile steels it really depends on your application.
If they are just prototypes why not just use a simple carbon steel.
