Hi all . Just wanted to talk a little bit about water stones and super steels.
Yesterday I decided to sharpen my spyderco k2 (10v).
I had pulled a lot of my stones out for lapping and decided to try a few of them on the 10v .
First stone I tried was a king 800. I did about 30 passes per side and checked my work, you could hardly tell that anything had been done . First time I've ever felt this weird sensation on the stone . It almost felt like the steel was cutting the stone .
Next up shapton pro 320 . It cut the steel but not like I'm used to with this stone . I used the 320 to get rid of some corrosion on the whole blade .
Then I tried the bester 1200 it cut the steel like it does with any other steel . Love these bester and beston stones they are nearly on par with shapton glass ,but a little cheaper .
After the 1200 I tried shapton glass 1k and 4k . They too cut the steel no problem.
So I've heard Jason b. Talk about diamonds and heard other folks talk about diamonds and how certain steels don't need them . So what happens when you actually use diamond plates on a steel that is hard enough to handle them for lack of a better word .
Well I started with the dmt xc plate . Instead of the normal feel of the xc ripping and tearing the blade 10v almost felt like it was skipping over the 220 diamond . I did my normal sharpening routine and off the 220 grit diamond I had one of the sharpest and cleanest edges I've ever put on a knife .
On of those edges that actually gave my arm razor burn and bit into the skin it was so sharp . I could of stopped here and been fine ,but seeing just how sharp it was off a 220 diamond I was curios as just how sharp I could get it .
I went from the 220 to 325 then 1200 then 8000 dmt plates . I used ultra light pressure and did alternating strokes only maybe 20 passes per side .
The results are probably the sharpest knife I've ever sharpened . I don't do hht tests or anything like that ,the edge could push cut magazine paper at 90 degrees off the 220.
By the time I was finished I was doing effortless slow cuts in magazine paper with almost no sound .
I don't strop my edges anymore because I like to test myself off of just the stones .
So the regular sharpening guys in here what's been your expierence with "super steels" and water stones ? It's obvious to me not just any stone will cut any steel so what water stones do you guys use on these types of steels ?
I still think only certain steels benefit from multiple grit diamond sharpening. However on these crazy hard steels diamonds can make an edge that will amaze you . It's not really that real toothy edge you expect even off on an 8k diamond either . 10v on diamonds feels as smooth as a Waterstone edge .
Kind of a long post I know just curious and wanted to share .
