- Jul 4, 2009
... without altering the knife itself!
I've wanted to "wave" my ZT0200 ever since I got it a few weeks ago.
While it has a small thumb ramp near the thumb studs that could be ground away to accomplish this, I also didn't want to do something to the knife that I would hate or regret later on. I wanted to keep it in at least "good/excellent" condition should I ever decide to sell.
What I came up with couldn't have been simpler. All I needed was a 6" length of 16 gauge copper wire and a leatherman multitool (I used a wave). On the leatherman, I used the pliers, the wire cutters, the file and nothing else.
A couple of notes before I get to the photos:
1) Why copper? It's pliable (easy to work with bare hands and pliers), and it's softness won't harm the blade in anyway.
2) I was extremely lucky choosing 16 gauge right out of the box - it fits within a few thousandths of an inch into the thumb ramp jimping, and it ALSO fits within a few thousandths into the space between the thumb studs and the handle when the blade is locked open. It was a miracle fit on both counts.
- The most important step here is the tightening of the "twist" with the pliers. That's what "locks in" the mod and secures everything.
I'll leave most of the explaining to the photos:
All you need:
Put the wire into the pliers about 1/4" behind the nose (roughly the same width as the blade):
Bend the wire into a "U" with a flat bottom:
Place the "U" into the second notch along the thumb ramp - it should nestle in perfectly - and send the copper wire behind the thumb studs:
Bend the wire around the base of the thumb studs:
Being careful to keep the copper wire as close to the base of the thumb studs as possible, begin twisting the wire:
Use the nose of the pliers to get it good and tight (but not so tight as to break or tear the wire)
Here's what mine looks like after it was tightened up:
Cut the wire, leaving about 1/4" of the helix.
Use the file to soften the corners and remove any burrs (be careful not to accidentally mar the blade).
ALL DONE!
HOPW YOU'VE ENJOYED THIS!
Kent
All you need:
ALL DONE!
Kent
