WE ceramic stone came loose - fix?
If it’s held with tape, you can call W.E. and have them send you a new piece. (I’m not sure what the ceramic uses).
It may be polyurethane. The “glue” looks like a silicone glue but the texture is a little harder and really sticks well to the plastic holder. Maybe I’ll call WE on Tuesday to see what they use. The ceramic stone itself itself is fine.
Seems like I read some where about Edge Pro stones . . . when you replace the stone on the aluminum blank plate you heat up the plate to get it off and put the new on one.
Maybe at the WE site they have similar info.
I've used Loctite Super Glue Gel before with good results. Should be easily found at your local hardware store or supermarket.
