WE Knife Trogon and its mastermind designer @brianbrownknives
It's WE Knife Trogon and its mastermind designer @brianbrownknives
Is this the one for you?
Nice design from a noted steel and heat treat expert. I'm a sucker for blue titanium which goes well with blue denim.
Wish the blade length was 2.99" to make it legal here in Los Angeles and make it lighter under 4 ounces.
SPECIFICATIONS:
Model Name: Trogon
Designer: Brian Brown
Overall Length: 7.77" / 197.4mm
Width: 1.19" / 30.3mm
Overall Height(Include Clip): 0.66" / 16.7mm
Blade Length: 3.2" / 81.4mm
Closed Length: 4.57" / 116mm
Blade Thickness: 0.16" / 4mm
Handle Thickness: 0.5" / 12.8mm
Knife Weight: 4.51oz / 127.8g
Blade Material: CPM 20CV
Blade Hardness: 59-61HRC
Blade Grind: Compound With Hollow Ground Primary Bevel & Flat Ground Tip
Blade Type: Spear Point
Handle Material: 6AL4V Titanium
Back Spacer Material: 6AL4V Titanium
Pocket Clip: Tip-Up, Right Carry
Clip Material: 6AL4V Titanium
Screws Material: 6AL4V Titanium
Thumb Stud Material: 6AL4V Titanium
Pivot Cap Material: 6AL4V Titanium
Pivot Assembly: Caged Ceramic Ball Bearing
Locking Mechanism: Frame Lock
WE’s got enough small 3” knives. Time to make some big ones. Looking forward to the Merata!
I did a search of WE folders on BladeHQ and out of 645 only 138 have blade lengths of 3 inches or less.
