Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Just got this in to bring in the New Year tonight, a very sleek looking knife right out of the box, a flipper on bearings that opens very smoothly and locks up well, closes nicely too. Detent probably could be a bit stronger, as you can sort of open the knife if you make a whip motion with your hands, I'd prefer a knife to not be able to do that, just for safety reasons but otherwise not bad.
WE Knives model 617A
Spec's
Padded zippered pouch
Closed length is 4.78"
Scales are of contoured black G10, all edges on the scales are nicely rounded/smooth
Lock is a nested steel liner lock with the lock bar measuring about .06" thick so it's not light duty
Hardware I am told is Titanium screws with proprietary type hardware which they did provide the tool to adjust.
Clip is also Ti and nicely formed and retains the knife well in the pocket. It is only right side carry tip up for the clip placement.
Back spacer has an oval shaped opening for a lanyard, I installed my BobTail fob on this one.
Blade length is just about 3.89" long and is made of D2 steel and has dual finishes, as you can see the wide flat ground side is black coated as is the harpoon type tip. The spine of the blade is also darkened.
Blade is .161" thick at the pivot area
Blade is 1.07" at it's widest point
Thickness at the edge bevel I am measuring about .025"
Handle measures about .59" thick
from the spine to the inside part of the guard area is about .85"
The G10 is textured nicely, not too coarse, also it is faceted somewhat as well, which provides a more sure grip than being too rounded.
I have no means of weighing this but from Blade HQ site they say it is just over 5 oz seems I may have taken the last one of this model, see this page for one similar from BladeHQ
I've only cut a little with this so I can not speak to how long the coating will remain unmarred, but not too worried as any abrasives it will just turn into a black stone wash look...I hope...
Cutting wise it works and feels very good in the hand, no hot spots that I can detect. The edge it arrived with was serviceable but will need a G2 tune up down the road...
Here are some images taken tonight.
IMG_6496 by GaryWGraley, on Flickr
IMG_6497 by GaryWGraley, on Flickr
IMG_6498 by GaryWGraley, on Flickr
IMG_6499 by GaryWGraley, on Flickr
IMG_6500 by GaryWGraley, on Flickr
IMG_6501 by GaryWGraley, on Flickr
The steel used is neatly marked on the tang of the blade, notice that the blade is pretty sterile and relies on the WE marking on the pivot hardware.
IMG_6503 by GaryWGraley, on Flickr
Nice knife, nice way to bring in the New Year
G2
Spec's
IMG_6501 by GaryWGraley, on FlickrThe steel used is neatly marked on the tang of the blade, notice that the blade is pretty sterile and relies on the WE marking on the pivot hardware.
IMG_6503 by GaryWGraley, on FlickrNice knife, nice way to bring in the New Year
G2
