- Apr 20, 2001
I recently picked up a 1971 Case 6347HP, good snap on all but the sheepsfoot blade, it's a little weak. Is there anything that I can do to strengthen it?
cpirtle said:How tight is the action on the blade?
I've seen knives that felt like they had weak springs because the pivot was too tight, if that's the case some gentle loosening of the pivot should work. Or just repeated oening/closing should help.
If the blade is loose or just right, it's probably more to do with the temper of the back spring or rocker pin placement. (The latter would imply that they all had weak springs and not just yours...) Not sure what you could do in either case short of taking the knife apart and having someone redo the heat treat on the spring...
cpirtle said:I wonder if brake parts cleaner would clear some of that out?
