- Apr 29, 2002
I have a hard-use folder that has some problems with the liner lock moving to the right after chopping.
I noticed that the problem disappears after disassembly, only to come back after only one hard chop to a piece of wood. The liner moves from almost completely to the left to the middle-right. Upon inspection, I noticed that the stop pin was being impacted by the blade, and this happened in multiple places along the circular pin(each place representing one disassembly and resetting of the pin). The point of impact is off-center, i.e. the wear mark is only on one side of the stop pin.
I believe that the pin is a stainless steel of some sort, while the blade is ATS-34. The blade shows very little wear at the contact point.
Is this a common occurence in hard use folders? If not, I'm going to contact the warranty department of the manufacturer, though I doubt that this is a problem that can be easily fixed.
