Weird double chisel idea
Here is another idea from my warped mind. I am wondering if this is possible: have a drop point blade, chisel ground on both sides, forming a double edge blade of drop-point on one side and wharncliff on the other. for clarifacation, imagine if the knives in the picture were a single knife, the picture showing both sides. http://www.ckg.org/Weyer%20Shots/19447.jpg .
Aaron
My sheep has seven gall bladders, that makes me King of the Universe!
aaronm@cs.brandeis.edu
Adam
I’ve played with this a bit and it does work but you have to be creative in grinding the point and warping during heattreat can be a problem.But it looks interesting when done.
The warp won’t be to the side but in a corkscrew shape.
It can be done it’s just a real pain in that blade style.
ED
Did you use the blade? My one worrs would be about lateral strength, there are only the two ridges, the rest of the knife would be pretty thin, right?
Aaron
Gentlemen: I too have tried this idea, and, as others have stated, it all gets messy at the point. Of course, if you double grind the Wharncliff, it's fine
RJ
You're saying a double ground wharncliff backed with a chisel ground drop-point. Sounds interesting. What about that arrangement makes the point easier wo grind?
Aaron
