- Jul 10, 2014
Post edited.
I've found that over time the DMT stones wear and parts of the stone will have a finer effective grit than other parts. It is possible that you may be putting more pressure on a particular area of the stone as you sharpen, and that section is giving you a finer scratch pattern than other parts. For me it is the center of the stone that is finer, and the corners are noticeably coarser.
Good day,
I keep a spare DMT duo-sharp folding sharpening stone in my ruck when I'm out on hunts for repairing my blades (I carry, while in the woods, a Kabar USMC mk2 and Cold Steel Espada 62NX, beautiful blades), as well as fixing a badly mangled broadhead if I honestly feel it can be used again and not cause undue suffering for the buck that it hits.
I've sharpened about 70+ machetes, utility knives, chisels, etc, and have even practised with a stropping band of leather for a straight razor. Still, I find the "fine" and "extra fine" grit DMT stones seem to dull my blades more than sharpen them. For example, I have sharpened a couple santoku kitchen knives a few times with a DMT "fine" stone (25 micron / 600 mesh), and it easily passes the paper test and cleaves soft tomatoes just by resting the blade on them.
I've tried the finer stones at the same angle (ie: 20 degrees, blade cutting towards the stone), and it seems to make things worse. Small sections of the blade seem a bit sharper, and more polished, but I get small sections of the edge that seem like they were sharpened with an aluminum baseball bat.
Is there a general technique that is applied with finer stones that would help?
Thanks!
Thank you for the advice on the appropriate forum. I looked over the topic list twice before posting.
With medium and fine grit, I just let the weight of the blade be enough pressure when drawing. Should I have to press harder when using finer grit?
I have those stones. The edge will get so smooth that it feels dull and won't cut as effectively as an edge with a bit of a bite. That is exactly why I parked my DMT Fine and Extra fine, and Extra extra fine stones and stop at the blue, coarse. It has much better bite on the stuff I typically cut. I have gone all the way up to mirrored like normally only seen with guided systems like Wicked edge ( I have 2 different guided systems) but I find that aside from being fun and impressive it doesn't really help. Try cutting ropes, especially synthetic, or skinning & caping an animal with coarse, very dirty hair and the coarse-ish edge does a bit better. Likewise ropes, tomatos, and meat ( muscle & tendons).
Try the same sharpening but stop at black, or blue DMT's, or Norton Silicone Carbide stones coarse/fine.
Joe
Care to share any other such secrets?![]()
