- Jun 10, 2001
This is one of those shop revelations that will help some and others will laugh at because it is so obvious.
If your using a file guide (If not it really helps) to file the slots on guards this tip is for you.
Be sure to place an extra piece of steel the same thickness as what you are filing in the bottom of the filing guide. This will keep the shoulders square. When you tighten the bolts you will see that the bottom half of the filing guide is cantered toward each other without support. This leaves about a .005 area that is not square on the shoulders of the guide.
Resulting in a slot or shoulder that is not square. This is where the little gaps happen that mess up your work.
Another thing I do is to place a small squeeze clamp on either side as I tighten the bolts. This also helps keep the shoulders square.
