If the top pick Ank is the edge restored there appears to still be a "tear" in the edge as you move from left to right it is the first mark on there .... if it is torn as deep as it looks I would be a little concerned it could go deeper ..... might not it be best to bite the bullet and grind out the tear and re-do the edge ?
My NMFBM has had a good few edges put on it and is a bit shallower than the original factory depth for sure .... but as you take away the factory edge you often find the Infi beneath it is able to take a much more lasting edge .... I think it might be to do with the speed the factory edges are put on the blades .... anyway .... that has the look of a "stitch in time" might save "nine" as if the tear goes deeper it will be a much harder job to sort ...... although sometimes photographs make things look bigger than they are .... but if it were mine I would sort that one out .... the others are fine and I have done similar myself ....
Dents, tears or rolls. INFI dunt chip mun.![]()
