Wet Forming Sheath For Fiddleback
I just purchased an amazing Kephart from another member and it came with a sheath. The sheath had been "wet formed" and the retention was like nothing I had ever seen before. I have a few Fiddlebacks that I got from The Knife Connection that came with sheaths, and I am considering trying to "wet form" them myself. Have any of you tried this? Do you have any advice on how to wet form leather or a resource that you could point me towards that would help me learn how to do this? Any advice you want to give me would be really appreciated!
Thanks!!
I did it with the the production camp knife. Just ran the sheath under a faucet and then went after it with a SMOOTH wooden piece shaped like a paddle.
PSA - If it's NOT stainless make sure to completely seal off the blade and tang with blue painters tape or you'll enjoy a rusty cleanup.
Cove the blade lightly in some Vaseline or other type of grease, then wrap the blade in a thin layer of plastic wrap before inserting in the sheath. You'd be amazed at how fast 01 tool steel (I assume it is)will rust when trying to wet form that sheath with your knife in there.
You could always try Saran Wrap in multiple layers. Most folks will use a bone folder for forming. Also might want to treat your sheath with a leather care product afterwards. If you have any more questions I am certain that one of the good folks over in the sheaths sub forum will be able to help you.
All the input on protecting the blade are spot on. Here's how I do it when asked:
Wet the sheath inside and out thoroughly, really get it wet inside and out. Put it in a plastic baggie and seal it. Let it stay that way over night to let the moisture level become uniform. This is called “casing the leather”. Take it out of the baggie and let it dry to the point that the leather looks normal in color, but is cool and slightly damp feeling. With the knife in place, use a very smooth round object to gently work the leather to the shape of the handle. Your thumb does an excellent job of this and I use an elk tine tip to finish up close. You are actually stretching the damp leather to fit the form. Once the form is done, put the knife and sheath in a warm, well ventilated spot to dry. I use a dehydrator for this step. Resist the urge to put it in the kitchen oven because an ovens lowest setting will still be too hot. As suggested by vile possum, when it's dry, use a good conditioner on the leather. Hope this helps.
Everyone has given some pretty good advice. So here's how I'd go about it. Use blue painters tape to cover the edge, just so you can work with the sheath, and not worry about the knife. For moisture protection I use grocery produce bags. The kind you find in rolls around the fruit 'n veggies at the store. They seem to be thinner than even saran wrap or standard grocery bags. If you don't already have something in mind for a smooth boning tool, many have used the handles of a basic kitchen silverware, table/butter knife. Many table setting styles have smooth stainless handles that actually work great. If your significant other had picked out table setting silverware with too many decorative ridges, stop by a thrift store and you'll find some great ones for $0.15.
Now wrap knife, wet leather (may take just a little, or a good amount of water to case depending on how it's already finished). If decorated or dyed with something water soluble, you may want to direct most of the water to the inside. Insert knife, and go to work smoothing to the shape you desire.
As Rick said above, drying in a slightly warm environment will help the leather stiffen a bit to hold shape. He mentioned to avoid an oven, but if you have an oven (or toaster oven large enough) that will go down 90-115 degrees, I've still used them. But keep an eye on it and check often. I have cooked a number of sheaths/holsters to the point of being unusable. Although, if I dyed a couple of the over cooked ones black, they may have been mistaken for kydex. ;) But just sitting out on a warm/hot sunny day will do the trick.
Be sure to come back and show us how it turned out....good or bad. We're all here to learn.
